big_ang
The previous owner left me a nice gift. I suspect the previous owner snapped a tap in the block and not just a bolt. I've heard of people using bolts that are too long, and when they bottom out the end pops off, but I don't think that happened here because it looks like the hole was drilled clean all the way through. Whatever was stuck was in there really tight and there wasn't enough left to be able to extract it. I drilled as much of it out as I could, but it was super hard. When I tried to tap it, my tap also broke.
The block is also damaged where the sump plate was hitting against the frame/side stand. I don't think the crack will leak, but the bottom of the bike was covered in oil.
I don't know what to do.
- I thought about just filling it in with JB Weld so oil doesn't come out and using one less bolt. This is the easiest option.
- The other option would be to put the bike on its side and drill a really big hole and then tap it again, to say M12. Then when I have a big bolt in with red locktight I can cut the head off and grind it flush. Then I can drill the hole and tap it for the M6x1 bolt in the right position.
What should I do?
Thanks,
Angelo
What should I do?
Thanks,
Angelo
