OakBehringer
XS650 Guru
Been searching, no solid results. Has anyone tried putting a latter model cam chain tensioner in an early model engine with a 6-hole plate? The tensioner arm was the wheel/sprocket type through 73. In 74 the arm type was introduced. Both years (73 and 74) have the same part numbers for their cylinders. There could obviously be more to the equation than this, but I'm tired as hell and thought I'd open it up for discussion. Proceed
Adam
p.s. This would be a desirable swap as the wheel/sprocket type is no longer available.
Adam
