ANLAF
XS650 Guru
I am about to swap jets and need some guidance.
I have had some great help from the guys, especially 5twins on the carburettors. I thought I would start this thread so others can see what is going on.
background - I want to swap the main and pilot jets from my 76/77 BS38s with the main and pilot jets of my 78/79 BS38s. The reason is I have pods and straight-through pipes so 5twins suggests if I want to use the 76/77 carbs (which I do) they will benefit from larger mains and pilots (and lowering the float needle one position) - 5twins says the larger 27.5 pilots and 135 mains will take me in the right direction to compensate for the custom set-up (pods and straight-through pipes), and lowering the needle position will make the mixture leaner to balance the bigger jets which deliver more fuel.
QUESTIONS
1. is there a guide to swapping jets - this is my first attempt, and I would like to do the reading first before I get in there; and,
2. re lowering the needle position, that is putting it to a lower number (from three to two) or is it moving it down the needle itself (apologies for the simplistic question, but I am not sure).
Carburettors are a mystery to some of us.
Anlaf
QUESTIONS
Anlaf
