wherearewe
Rub on Ya Titties
Hi All
Needed to replace my tach cable so I figured i would replace the O ring and seals while i was in there. Normally i always do a little light research before i dive in but not this time. Anyway i pulled out the tach cable, removed the bolt that holds the mechanism in place, and lifted out the unit (parts 1-4 - thanks 5 Twins I borrowed your image).
No worries there. But for some reason I decided to begin lifting the drive shaft (part 7 - not sure what its called). Stopped after moving it about an half an inch, figured I should take a moment to see if that was really necessary.
So my question is, is there anyway i can tell if the lower washer remained in place or do i need to open her up. It all seems ok but what should I look for? Will it travel further down and not mesh with the cable inner?
Churs
Churs
