Just got my led's and having issues w/blinkers, I think it's probly in the HL bucket. Got the orang to work as running in the rear tapped into the blue at the connector (temp,test)
OK I'm pretty unclear as to what you have, how you're wiring it. and what the issue is??
Reread; and you are saying black is ground and orange is a running light? Then red is the turn signal bulb?
Do you have a diagram showing what the red orange and black wires do?
I'm assuming blinkers AND running lights?
Using LEDs and resisters is kinda like buying a rain coat then cutting slits in it for better ventilation.
That resister is two in one package? Blacks to ground one red to each side of the turn signal circuit?
I greatly prefer using an "LED" or HD flasher can that doesn't depend on the bulb(s) resistance to create the flash rate like the stock flasher does, rather than adding in load resisters....
