Also note that there are significant differences between thread forms on tapered pipe threads and their unions, eg: NTP and NTPF.
IMO they each have a place.
Where pressures are low (<45 psi) and tempretures are low(<280*) where fluids are concerened I would promote the use of NPT pipe taps and dies along with the use of teflon tape or liquid teflon sealants. (Slightly hotter up to 400* with proper sealants.) Above that and where heated vapors are included with fluids above 60psi I would elect to go with NPTF taps and the dryseal type of fittings. Special care must be used with NPTF taps and finess assembly techniques used for dry seal fittings. (1 application only) When properly applied this thread form will provide superior sealing.
It is a matter of opinion where the fluid and vapor pressure break points are for the thread form use, Vickers says this, Kawasaki heavy says that, Sunstrand, Catapillar, Hitachi all say something different and I've seen a lot of teflon tape on 1,200 psi systems. I don't like it but I've seen it.
Just be aware.
I will be cutting dryseal (NPTF) threads for my oil feed lines but not so on static drains and plugs. There I will be cutting NPT and using #565 Teflon Thread Sealant.
My favorite motorcycle manufacturer knows this now and engineers appropriately. Until reletivly recently ('83) AMF had ignored this. 7 of the 8 pre '84 american v-twins I have owned never leaked a drop after my machine work, except the '49 EL which is supposed to expell oil in two places by design. The other 7 shovelheads did so from the factory but I know how to seal them up, I am sure many others do as well. I picked on Harley because of the stigma they carry, I've owned countless metric bikes that rarely leaked as well. I despise oil and vapor leaks, it's just not acceptable. LOL.
