Wanted - Tci for a 1983 xs650
what specifically are you looking for? the pickup that mounts over the flywheel? the ignition box itself? or a complete setup including the pickup, the matched flywheel, the ignition box, and a coil?
I have this box from running bike,
I need the ignition box and a ignition coil at a decent price
Motrhedd is that box from a 83 and or will it work?
If you look at the plug for the '83, you'll see it's an eight plug with seven electrical connections. The earlier six plug will work in the later eight plug. The seventh connection not being used is for a lockout safety feature.
If you check the schematics for the '82 and '83 TCI you'll see. I've used the six plug tci in an eight plug harness.
