TCI Replacement 2020 It Works
Think I'm going grind off a little off the wings to allow the pickup to move up a little so it will clear the the cover.
The 3/8 nut on the allthread grips the id of the cam pretty well.
Next is getting the pickup fastened to something so I can see if it makes spark at kick start speed.
Got to take a nap first.
I did watch the video from Chrysler # 1452 and the shape of the reluctor Tooth can be important
15:33 ish wants sharp edges and the gap settings Perhaps you checked this already on the oscilloscope
Was hoping to get away with a unmolested wingnut.
Close, it sparks when I spin the allthread thru the cam but no joy kicking it even with the plugs out.
I have been trying to keep the amount of fabrication, fuzzing around to a minimum.
Jan_p was spot on about the difference in shape and profile.
It looks like the the wingnut will have to face the grinder. Or some other fate ????
The good news is the pickup alines with a coupe of holes in the yamaha points plate.
Just for input .Thinking out loud.It would be possible to bend or weld an U shaped profile and perhaps have an adjustment
possibility having the pointed shape for the reluctor and being able to use shims or so get the right distance
I share an image of an adaptation of a group of xs650s from Mexico. I think a little modification to the wing nut might work.
They are just two pieces of metal welded together. Personally I wouldn't want to mess up the cam without a replacement, it's easier to get those wing nuts and modify them.
Ah, I see. Looked like magnets to me. Thanks for posting.
Do you know if the ignition works with that pick up? Is it Yamaha TCI, or something else?
My thought exactly. .89c wingnut vs who knows what for a repop points cam.
What I'm curious about is where did the washer for a backing come from. Washers that size a hard to come by
. There again don't want to add holes to original points plate.
The wingnut is going to work. The factory gap for the reluctor is .008 inch. I'm not running it nearly that close more like .8 of a inch. I working on tightening that up.
Right now I have a old design reluctor with magnets installed right now.
Have spent the day prepping for a squall line that's coming through so not so much Gonzo.
The design goal here is something that someone can reproduce with not much more than an electric drill.
Worst case I will drill holes in the wings and mount small magnets to boost the signal.
Will that be a dual output coil , wasted spark? Or two coils two sparks 180° apart?
Wasted spark. Ether a TCI style dual outlet coil or the points coils in parallel. I prefer the the Honda cb750 style dual output coil myself.
One thing I like about this mod using the Mopar pickup is that the Mopar electronic ignition first appeared on a 1973 340 hotrod engine setup so it is a contemporary to the 650. This setup could of been done back when the 650s were new.
If you use the stock points wiring for the pickups and the stock coils the whole mod is pretty stock looking from the outside.
Haven't had much of a chance to work on the Gonzo. Made a 500 mile trip to Houston and back on Saturday and Sunday. Wow things have changed out there on the super slab.
Yesterday I rigged up the Mopar pickup and v8 reluctor to a GM HEI.
Result "Sparkulation. :)
The gap is closer to .125 than .008 factory spec but it makes sparks
I really like the HEI module. Pretty small and straight forward to use. This setup require the stock advance unit and attaching the mopar reluctor is a challenge on the stock advance rod.
Stock mopar distributer setup. The reluctor is roughly 1 inch in diameter . One of the smallest I've found.
Next phase modded 2 lobe mopar reluctor and Gonzo.
And the wingnut will meet the grinder.
Since the advance relies on the leading and trailing edge of the trigger to determine advance (that's my theory anyway), you could always vary the thickness of the wingnut to reduce it if it's too much.
I'm pretty sure the advance is set by the frequency of the pulses and not the width.
Hope to confirm this soon. Next step after getting this thing secured to the bike is put some gas in and see what it does.
