Mister Mellow
Big Dreams, Thin Wallet
My stock aluminum wheels are straight and true. Whoever laced them did a beautiful job of removing any trace of vertical or horizontal movement, and they are both perfectly centered on the bike. The problem is, when I ping tested the spokes, ALL the spokes on the right side of both wheels ping nicely, and ALL the ones on the left side return a dull thud. I checked for broken spokes, and they're all good.
My question:
Obviously, the loose spokes need to be tightened, but what will happen when I do so? I have only laced one wheel in my life, some 30-odd years ago, but I remember the basics. This is a weird problem, and I'm scratching my head trying to predict whether the rim will move horizontally when I do this.
Should I ONLY tighten the loose ones (evenly), or should I correspondingly loosen the tight ones as I go around. My fear is that loosening the tighter ones (on the right) will move the rims to the left. My current thinking is that, if I leave the tight ones alone, they will hold the wheel where it is, while I simply bring the loose spokes to their proper torque. But I'm not certain of this.
My question:
