xs650newb
Hi Everyone,
Going over my project today. I got it running for the first time yesterday which is great.
I went to change the spark plugs and when I took out the left side plug I noticed it had this threaded sleeve on it. I checked the spark plug hole and it someone obviously re-tapped it to a larger width.
The sleeve looks like the picture below. Although it is black.
As I see it I have 4 options. Give your opinion if you can.
1) put sleeve on new spark plug and ignore problem
2) take insert, use red loctite and screw into hole. then put anti-seize on spark plug threads and never ever over tighten
3) check to see if my helicoil inserts have the same outside threading. If they do I can put one of those in the hole then add red loctite and use that special tapered punch to widen the insert so it sinks its teach into the aluminum.
4) Find a spark plug which is wider and has the same length.
Thoughts?
Best,
Adam
Thoughts?
Best,
Adam
