I'm running a set of Keihins on my XS chop and having some issues with the throttle cable.
1. the cable is wayyyy to long
2. i'm using a harley aftermarket throttle for my 1" bars, when hooked up the carb slides are already half lifted, and the cables are adjusted all the way.
I tried cutting some length off of the outer casing to make it work, when doing so I ruined the cable..
So my question is, where can i get a 2-1 cable that will work with the keihins and also work with my harley throttle.
Heres the throttle im using:
It was only cheap so i dont care of it involves getting another throttle to make this setup work.
Someone help me out!
