hello all, new to the forum and xs650s, I bought a basket case 77xs to build into a swing arm chopper, I had to make the wiring harness, as the bike pretty much came with engine frame front end and wheels, The problem i am having is the right cylinder is shooting flames thru the carb,
Motor has great compression on both cylinders,
carbs are freshly rebuilt,
pamco ignition system,
the plugs are firing good,
checked the coils,
plug boots,
valves are adjusted properly,
timing is set,
timing advance isnt binding,
back fire wont go away with any play of ignition plate,
left side runs great, no back fire, pipe gets good and warm, lots of pressure shooting out the pipe,
right side, back fires thru carb, combustion is happening early, so no warm pipe, no heavy pressure from the pipe, and is ruining my fun
if any one has any ideas , or things that ive missed, id realyy appreciate it, i feel i got the bases covered and should be sliding into home, but defintly not working out
thanks
checked the coils,
plug boots,
timing is set,
thanks
