mvonwahlde
I've been working on getting to a "rideable" state on my build and I have the engine kicking over and running (though it races after it warms up... so I'm guessing air leaks are to be diagnosed...) and have to time the ignition.
When I first installed the advance unit the "pin" was upright. I marked TDC on the case/cover and marked the rotor with a pencil. I found TDC by sticking a chopstick in the spark plug hole on the right of the bike and stopping it at it's highest point when the engine turned.
I've since pulled the advance a bunch of times to deal with ignition issues, but have always reinstalled using all the pins.
In trying to time the bike for the first time using a Harbor Freight timing light hooked up to the two battery terminals (positive and negative) and then the little slide/sensor thing over the spark plug wire.
With the engine running, I am seeing the mark on the "top" of the rotation of the rotor instead of on the bottom near the TDC and timing marks.
So what did/am(/will) I do wrong?
The engine runs, it kicks over first try with a little help from a spray of carb cleaner (guessing I have fuel supply issues that probably require another jetting or rebuild of the carbs)... but it is giving off a decent amount of white smoke from the left cylinder (the right only a tad on start up, but this is a fresh rebuild... the last part of it by me (the first 2/3 by the PO).
