Hello,
So I have a 1975 XS650 and I have been jacking around with the timing. I first checked my valve clearances and there were a couple that were off, then I gapped my points and moved on to the timing. Started with the right side made sure I was in the compression stroke piston was at TDC. Then I busted out my timing light started with the right side put the strobe on my timing marks and the best I could get it was the T mark should I be setting the timing on the F mark? I adjusted the plate but the best I could get was to the left of the T mark (near the F mark) on both cylinders. She starts up first kick and sounds strong just want to make sure I don't have any future problems.
