1972 Yamaha XS2. Frame and engine numbers match. Clear title in my name. Starts with one kick, electric start is not currently working. Starts, runs, and shifts through all gears. Paint is faded. Chrome does have some pitting and surface rust on areas. Handlebars, exhaust, and rear fender support have the most wear. Interior of tank has been sealed. Paint is worn off of the rear of the tank where the seat has rubbed for years. There is a scraped area on the front of tach housing. Turn signal flasher does not work. Signals must be turned off and on manually. Motorcycle is over 40 years old and has not been restored. I do have the front signals and will include them with the sale. One lens is cracked. Baffles are loose inside mufflers, but they still sound good. Below is a list of parts that I have purchased, installed, and have receipts for. No smoke. Odometer is reading 200 miles higher than the picture. As is where is sale. Please refer to the images for an accurate representation of the motorcycle.
Wiring Harness
(2) Air Filters
Right & Left Throttle Cables
(2) Muffler Clamps & Joint Nuts
Rubber Center Stand Stops
Basic Pamco Ignition w/ E Advance
Oil Strainer (sump Filter)
Oil Filter in RH Engine Side Cover
Drain Plug Copper Crush Washers
Carb & Oil Filter Gaskets
AGM Battery
NOS OEM Drain Plug
Fuel Lines & Filters
Petcocks
New OEM Brass Floats
$2,500
Wiring Harness
(2) Air Filters
AGM Battery
NOS OEM Drain Plug
Petcocks
$2,500
