To give you more and better advice, you need to give us more information. We need to know if your carbs are the stock '77 ones or some aftermarket carb, what mods you have (like exhaust and air filters), and if stock carbs, what jetting you've changed to.
If your carbs are stock, you may have over-jetted. It's easy to do on CV carbs because they're very forgiving. They'll still run, although maybe not very well, if the jetting is too big. Your #30 pilot jet for instance. The stock '77 size was a 25 so you're 2 sizes up on that. Normally folks go one size up (to a 27.5) so that 30 may be a bit much and contributing to your dark plugs.
