torque specs on bolts replacing rivits on primary gear set
urbandork
How tight should the bolts replacing the rivits that hold the primary gear onto the clutch basket be?
- i have a set of these from terry in aussie with the vesconite blocks...he recommends
- 7 - 8 ft lbs only...use loctite 262
coolios thanks a bunch ... I to am using the same vesconite blocks along with the high ratio primaries
