Tron
Bearded Sheep Whisperer
Hey all,
So my bike was running a bit rough so I did some tuning..Before, the right side was running hotter and the left side was fouling the plug ever 100kms or so. I realized the valve clearance on both sides was WAY off. The right side seems/seemed to have a sticky rocker as well.
So, I Re-set the cam chain tension, valve clearance, and tried to bench sync my carbs.
I have played around with the syncing so much that it seems like there MUST be something else im missing.
Both sides are running hot, but left is a bit hotter. The right is popping and backfiring a bit, and from idle off the line, the right side struggles a bit. The only other issue is when I shift or let off the gas, the bike revs a bit, and doesnt drop back down.
The throttle cable is new, and not the problem.
ANy ideas?
ANy ideas?
