jurgenkoppen
Backwoodsfreak
My bike, a 78, fell over on a soft lawn, nothing obvious broke. Only my left turn signals function died on impact, so I checked the bulbs, but they were fine. I reversed the wires connectors in the headlight bucket, the ones coming from the switch going to the rear and front connectors: Now my left signal side work, but the right ones are out. So I figured: must be the switch itself, because from the switch back all systems are "go". I disassembled the switch, and sure enough, the solder joint had separated on the brown cable. I soldered it back on, sure of impending victory, but alas, now there is current to the flasher relay, but it only buzzes on the one side, and works on the other. So I tried a two prong flasher relay which works on my xs11. It works great on the working side, but blows the fuse on the troubled side.
Now if my logic is correct, I would say there is no short on either right or left side, because I can reverse the supply lines from the switch, and make either side work. So the fault which causes the buzz in my old relay, and a blown fuse in the 2prong relay, must be still in the switch? I also disconnected the cancelling unit to eliminate chance of it being the short, but now I am baffled. Any ideas?http://www.xs650.com/forum/images/smilies/shrug.gif
