Hello All,
Thanks in advance for all the help. This is my first time posting, but I have kept my self busy for some time now, rebuilding my basket-case '82 XS650, with all the info from the tech section and previous posts.
My question now, which I have seen discussed briefly in other threads, involves the use of oversize piston rings on stock pistons.
My situation: I ordered some used "stock" cylinders and pistons to replace the originals that had been seized. It appears that they have been worn / honed to the point where a new set of piston rings do not fit within maximum spec - the end gap is too wide. The end gap with new standard rings in the cylinders measures about 1.15mm.
Is this a situation where I could use oversize piston rings filed to the correct gap? Or should be looking towards oversize pistons aswell?
