TeeCat, I have a Vacuula profesional system for flushing out larger system's. with that said, all you really need is a good sized (20 oz.) glass jar with a top. Put a hole in the top to let a small piece of tubing through. Put about an inch of clean fluid into the jar, lid on, hose into the jar with the end submerged in the fluid, the other end on the bleeder. What I do then is open the bleeder, and let gravity do it's job. Once I have a good kinda steady stream coming out of the caliper. I close the bleeder, pump the hell out of the lever until I start to get a stiff lever, then bleed until no more air. All set to go. BTW, every time you open the bleeder, you do lose alot of the residual pressure, so pumping the lever will be done several time's. I like to use a big jar, for more time between emptying the old fluid. And glass so I can see when it's full.
