"Of Course We Have A Plan. You Have To Have Sumpin To Deviate From."
The ATOTO 7 radio/navigation panel I installed came with a backup camera. Good a time as any to install it. It mounts to the license plate holder. When I tried to fit it, it covered the license plate light. Drilled some new holes in it and it's offset just enough.... I hope.
To route the video cable through, I filed a little notch in the plate holder so that when the light fixture is installed it makes for a tight seal.
This whole affair is one big pain in the ass to access. The little plastic screws that hold the light fixture are the type that you push in and (supposedly) screw back out. Yeah... good luck with that. I had to force 'em out from the inside. Bought new replacements but I don't trust 'em... and I don't want to have to tear the door apart again to replace the light, should it ever blow... or WHEN it blows more likely.
So I went and let Advance Auto rake me over the coals to the tune of 20 bucks for a pack of two LED replacement bulbs. They don't sell singles.
Installed it and checked it at dusk. The camera still kinda sorta blanks out the two left digits on the plate. Maybe they're more visible when it's dark. I'll check that but to be honest, this van will see very little night time driving, if at all. My night vision has gotten worse over the years... and Sue's was always pretty bad. This is a day van. Night driving only when absolutely necessary. Anyway, I got a little sidetracked here. Let's continue.....
When I initially installed the ATOTO 7 head, I ran the cable for the camera out the left side of the instrument panel and just looped it up in the back of the van. Well, today I had one of those "what the fuck was I thinking" moments. Cable's ran down the left side and the camera's installed in the right aft door.
Yeah... as you can guess, it weren't long enough.
As it happens, I found a glitch in the new instrument cluster from Circuit Board Medics... the odo and trip meter went dim on me. Worked fine when I first installed it, but I went to reset the trip meter when I gassed up and I couldn't read it. Called the the C B Medics up. They apologized and said they'd get another headed my way. That was Wednesday, it showed up today... good service. So anyway... gettin' a little long winded here...
Since I had to tear the dash apart anyway, I pulled all the camera cable back up and out the right side of the dash, up over the right door and back to the right rear door. To get through the flexible conduit to the door, I ran a piece of 7mm ignition wire up through the conduit, taped the camera cable to that and pulled it through.
I temporarily connected the signal wire to the backup light and sumbich, it works....
Went ahead and replaced the instrument cluster and I have my odo and trip meters back...
So yeah, what a day... what a fuckin' day. I think I'm gaining on it... who knows... whew, I'm beat.
