On these CV carbs, to properly test main jet size and needle setting you need to use absolute wide open throttle. From about 3 or 3.5K in 2nd or 3rd gear, whack the throttle wide open and run the bike up to near red line. Watch the tach and look for break-up or stumbling in the 4 to 5K range. That would indicate either your needles are set too rich or your mains are too big. Due to the forgiving nature of these CV carbs, these glitches may not show up unless you use the full throttle test. Obviously you won't be riding the bike like that normally but it's necessary to test the jetting that way.
