Ok Ive searched our site and read lots of posts about pamco, e-advance hooking up. Ive got the pamco and e-advance working fine. My problem is I want to hook up a electronic tachometer in my system. I read one post where you wire the green tach wire to the negative side of the coil. I also read that the green wire of the e-advance is the negative side of the advance unit. I hooked up the electronic tachs 3 wires red, black and green. Red to + fuse block, black to battery frame ground and the green one to the green wire from the e-advance units green wire going to coil. My tach lights up and reads 0 rpm. Do I have it hooked up proper or is this new tach defective? I also wired in a 1m ohm resistor. Any thoughts on this? thanks
