jb_supermoto
There is a hole cast into the engine case just above and forward of the CS on the left side. There is some sort of steel plug or something in it. I don't think it is there on the later engines. Mine is a '72. There is a crack in the case that a PO welded, and it looks like it was from a chain break incedent or something. Anyway, it appears that a PO filled the hole with silicone sealer and it was leaking a little oil. So, I dug out all the silicone and the pic is where I am now. I am going to fill the hole and crack with JB weld (I know, hillbilly fix, but the next step would be to remove engine split cases etc.). I just want to make sure there is not something servicable behind that plug that I will need before splitting the cases.. Any thoughts? And yes I know the clutch push rod seal is missing. I pulled it out to replace too. Thanks -
