WOLFHAWK
Stuff is taking up space in my room and I don't need it.
Front fender (had intended on using it for the rear but am going a different route)
Rear fender (cut back a few inches, stops right at the end of the rear loop)
Megaphone muffler -slight surface rust near the front, light scratches, baffles still in there.
Cluster with bracket
Speedo (believed to be working as per P.O.... took it off before I ever rode it)
Yamaha tank badges (one is cracked across the Y, other is cracked at the Y and the A) Pending
Turn signal and horn switch (works, turn signal switch sticks -may be salvageable if you get in there and clean er up)
Rotor/flywheel (edge chipped off when my roommate knocked my workbench over) Gone
Alternator -worked when removed
There's also a TCI box I didn't feel was necessary to take a close up picture of.
I got it from a member on here a little over a year ago and it works.
I'm located in Kingston, NY.
About 2 hours north of NYC/ an hour south of Albany.
I can ship anything with UPS ground through my job for pretty cheap.
If nobody wants any of it it'll just go in a box in the corner and forgotten. Or thrown out.
I'll be adding a few items to this when I start cleaning the garage.
