ANLAF
XS650 Guru
This is the story of a PO trying to kill someone - me!
I have been trying to work out why the front end on my chopper was tending to flop to the left. Well, yesterday found the nut on front wheel main shalft bolt was loose. I tightened and got to 58lbs of torque, new split pin and set off on a ride.
Five miles out I became away of wobble at the front end. I slowed and had a big truck trying to overtake through my exhaust pipes. Then the wheel started wobbling and me saying Woooowah! I managed to stop. Got the bike home in the back of my trusty VW and persuaded the front wheel to come off. The front right bearing had fallen apart, the left side bearing was only half seated and half out.
I stripped and cleaned everything and examined to find something which sent shivers up my spine - this is my first meeting with wheel bearings, but even I worked out that two properly fitted bearings will have a spacer between them so that when the torque goes on the inner bearing race (the inner ring of the bearing) is held fast against the spacer.
Hmmm! the spacer on my bike was a goof half an inch too short. It was doing nothing, so when I tightened my main nut it squashed the hell out of onle nearing and all but pushed the other out.
Help
1. is there a way to measure the correct length of the spacer I need?
2. are there any other spacers, washers, shims that go between spacer and bearing?
Anlaf
Help
Anlaf
