Which engine is the better one?
There's several stuck piston pusher ideas round here. I've gotten out some severely rusted ones. it is very important to send them both down at the same time or you can damage crank, connecting rods.
Never personally heard of anybody trying the method you suggest. I'm not saying it wouldn't work. Might make a lot of mess, but you would have to be ready for swarf everywhere. And it might be that the pistons are better stuck than most and reluctant to shift.
What usually works is releasing oil, leave it a while, then tap the head of each piston with a wooden drift, typically start with a hammer handle, working around the edge of each one and increasing the level of force until it moves. Have you looked at 5t's patent piston pusher? I guess you have 'coz you've seen his ingenious engine stands.
Good luck!
Good luck!
yeah, tried all kinds already, I'll keep on going, drilling the pistons is my lat option!
off for night-shift today,
working on seized motor, no chance to move the pistons, found out the reason the starter where in a box, homemade plug, hard plastic with a bolt thru the case cover, not too bad, the starting gear still in the lower case,
Wasn't HE clever!
Hey Gary,
A kind of clever or smart?
Have you seen the picture with the extended clutch spring? What was the idea behind that?
Think now this guy knowed what he did, maybe on a low budget,
I remember bought this motors 10 years ago in Ontario, Owen Sound the guy had some other bikes, English bikes in his amazing two story heated barn, I was impressed,
Was a long hauler that time, Canada USA, stopped on the way home to Nova Scotia, load the 3 engines behind the Cab between the tractor trailer, on studs secured with a couple ratchets straps, never forget that, still have the phone number, may I call him some day
So every engine, every bike I ever owned have there own story,
You guys may have the same background with every bike you owned,
Would be a idea for a thread?
Hi Scrapmetal, I thought so too, so I started this thread:
http://www.xs650.com/posts/606400/
I could easily add stories about probably most of the bikes I've owned.
....... the picture with the extended clutch spring? ......
Didn't find it.
On pushing pistons; make your pusher so it connects with the outer edge of the piston, the crown is thin and can be shoved in, not that it matters to the piston but it won't move the piston in the cylinder. Need to watch that you don't keep pushing after the crank has reached BDC! At some point you need to block up the cylinders to keep pushing the pistons out.
done!
had a nice conversation in German and English with the sized Motor,
the conversation, soaked in mystery oil for a couple days, heat from the torch, some gently touches with the hammer on the hardwood chisel,
RESULT: apart without further damage, BINGO,
talked with my buddy, he owns a bike shop, quads etc. he will drill the cylinder for the next oversize pistons,
pic 5 shows the damage lower case I'm replacing with he case from the sized motor, pic 6,
pics 7 , 8 and 9, working on the engines without having a motor stand
Stock bores are just over 75mm, stock pistons just under. On a stock piston, there is a 3 digit number stamped into the top, but you'll have to clean the piston off real good to see it .....
The 3 numbers represent the fractional part of the piston size, as in 74.xxx mm. The 3 numbers replace the 3 x's. But your piston tops look a bit flattened out, maybe from pounding on them, so maybe the numbers won't show any more.
Oversize pistons go in 1/4mm steps. 1st oversize would be 1/4mm bigger and have a "25" stamped on top. The ones I linked to are 2nd oversize or 1/2mm bigger. They would have a "50" stamped on top. If you can't find any number markings then your only recourse would be to measure them. The stock piston in my pic above new was 74.953mm. All I've seen are very close to 75mm, like in the 74.9xx range. That means even the 1st oversize (.25mm) would put the size over 75mm.
706cc kits also available... It's trickier doing the 706 bore cuz that's about the limit for the liner.
