LocoKen
Mike's is out of the #42.5 Pilot Jet BS30/96 type which is the stock for my BS34's. What would you guys recommend in place of them and/or would you also replace other things as well if an alternate is used? Thanks.
Couldn't find any BS34 parts on the Sudco website. 650 Central has some but I'm wondering if they are knockoffs or OEM. Hmmmm......Mike at 650 Central can help you out. You can also go through Sudco
Thanks 5twins, JR Roxx. I will do just that. Thanks for the tips. Didn't realize that they were that popular in many carbs. Again, thanks!You're not buying "BS34" jets, you're buying Mikuni BS30/96 type pilot jets. They're used in lots of different bikes. I get mine sometimes at several of the local shops around me (if they have the size I'm looking for). Shops out in the country that cater to dirt bikes, ATVs, and snowmobiles usually have a good selection of jets on hand.
Same thing goes for your main jets. Your BS34s use the large round style of Mikuni main, pretty much the most common main jet on the planet.
Just to echo what several informed are saying....you're either getting Mikuni jets for your BS 34 or BS 38 CV carburetors or you're not and in my opinion it's important! First thing to learn is what the specified designation should be, what you have or find to be in your carburetor and then what you want to get and have.
I've found a number of good sources for same like 650 Central, Dennis Kirk, JC Whitney, Yamaha dealers, Powerplus, Z-1 Enterprises etc. But you are the one responsible for knowing, specifying and ordering the correct jet and size. Sadly many don't know the details of what they have or want. So....those selling knock off's abound.
Here'a a good site with information supplied that can help you figure it out (assuming that you know your carburetor Mikuni CV carburetor BS 38 or 34 and OEM jets supplied by both type and size.
http://www.pjmotorsports.com/mikuni-jets.html#pilot/slow jets
Really good information displays and sourcing though a bit more pricey than can be found other places. You will have some homework to do re both the correct designation of what you have and what you want. PJ's charts are most helpful in this regard. Yes, you'll be back into the oft referenced carb guide of 5twins an Grizld1 http://www.amckayltd.com/carbguide.pdf to learn of both what you have and want. Blue
