1. Dismiss Notice
    Dismiss Notice
Which pads for unknown calipers?
Discussion in 'The Garage' started by Muckroot, May 22, 2020 at 10:43 PM.
  1. Muckroot
    Muckroot XS650 Enthusiast
    I have a caliper assembly that fits the 34mm forks I'm running on my hardtail project. I cant figure out which pads to get from mikes though, because two of the options have key tabs on them. can anyone eyeball this caliper and let me know which of these two sets of pads is the correct set?
    IMG_9672.jpg IMG_9673.jpg IMG_9674.jpg IMG_9675.jpg IMG_9676.jpg IMG_9677.jpg
    https://www.mikesxs.net/yamaha-xs65...06-25811-05-1a1-w0045-00-1a1-w0045-00-00.html
    https://www.mikesxs.net/yamaha-xs650-brake-pad-set-2-xs2-tx650a-round-oem-1a1-w0045-00.html
    Also, in the pictures I've already blasted the calipers with baking soda as best I could. Do they look like they'll run safely with a fresh set of seals? Also, should I pony up the 40$ to buy new pistons for this caliper? if so, is this the correct piston?
    https://www.mikesxs.net/yamaha-xs650-caliper-piston-all-fronts-1972-76.html
    Thank you all for enduring my endless noob questions;
    Best, Muckroot
    Edit: forgot to add the pictures :umm:
    gggGary likes this.
  2. XsJosh
    XsJosh XS650 Enthusiast
    Those are calipers take stock 75' pads I know because that's what I used in them. I think the pistons will be fine with a little clean up with fine Emery cloth and some new seals. The corrosion on the inside of the pistons does not matter it's the outside where the seals ride that you have to worry about.
    Muckroot and gggGary like this.
Share This Page
