White (color) throttle/clutch cables
Kmunshower
"Suck it"
17019
Getting close to the point where I put everything back together. I'm trying to get or locate as many things now so it can go smoothly. There is a lot of blue on the bike, (frame, tank, forks) that I wanted to break up the color somewhat whit white throttle and clutch cables. Anyone know where I can find them? I can't use the standard length as I put mini ape hangers on it. (12") :banghead: I should have measured everything before it came apart.:banghead:
Thanks
Why do my pictures always turn!!!
because the pics need to be wider than tall... easy way to find needed cable length get some 1/4 polyvinyl hose to act as the outer casing it's stiff enough to make routing layout then measure needed inner cable free length off a regular cable.... right on Pro-Motion should be able to set you up don't know about color tho'
