Just got my Basic Pamco Kit from MikesXS, but I can't figure out how to wire up the new 17-6903 coil. After removing the condenser, I'm left with a turquoise wire & a green/yellow wire. I traced both of these back to the same terminal on the ignition switch. Based on the Pamco install instructions, it looks like I only need to reuse the hot wire that goes to the kill switch, & splice that one into the same connector as the red wire on the Pamco unit. Since both of these wires go to the same terminal, am I correct in assuming that I can use either one to power the coil, & the other just gets capped off & tucked away?
