No, they're different sizes (diameters) so no way to adapt them. There were also two different BS38 slides. The difference between the two is in how the needle mounts inside, also how high up in the slide it sits. In '77 and older slides, a shorter 4 series needle was used because it sits down lower in the slide. The '78-'79 slides use a longer 5 series needle because it sits up higher in the slide (on top of a little spring). On both slide types, the amount of needle hanging out the bottom ends up being about the same. The BS38 slides will swap with each other but you will need to use the appropriate needle with it, and maybe it's matching needle jet too.
