I looks like I might need a spedo. Let me know if you have one.
Can you take a few more pictures? I want it. How much for delivery?Yeah the speedo is a bit pricey, long story it was SUPPOSED to have been an XS1 speedo.
How about 1200 on the XS2? It kicks through seems to have decent compression. New wiring harness. Tank is lined, paint is shite rattle can. Can do a photo shoot if yer (or anyone else) interested.
NEW SS spokes 18" front AND rear WM rims, Dunlap K70's 2020 date codes............. rest of bike is meh, a bit dolled up, but it sat out for a long time. Clean old title, not in my name. A ride to NE Georgia can happen.
Thanks.Have blinkers, seat is aftermarket, battery seems good, airboxes gone, only one chrome chevron, side covers/ emblems are from a 73 grab rail prolly factory.
Sounds great. Nice bikes on the trailer. I will have $1400 cash on delivery.
Prolly cash on delivery works best. Sometime within next two weeks is most likely. Need to decide van or prius and trailer.
I copied the following from the Caswell website:Coated over rust. Never seen that before.
Thanks for the info. What is the name of the Product?I copied the following from the Caswell website:
"This Epoxy has much better bond strength than single component products, with strengths of up to 3000 PSI, and this higher strength reduces the need for a clinically clean surface, as the epoxy actually prefers to bond to a rough rusty surface. Our new phenol novolac is more thixotropic, which means it 'hangs' on the tank walls during the coating process."I have used their product in the past and will use it again, however, I have always applied it to clean metal and will continue to do so. I close friend of mine applied it over the top of rust and a failed liner and it has been holding up for several years. Still, I wouldn't do it.
https://caswellplating.com/epoxy-gas-tank-sealer.htmlThanks for the info. What is the name of the Product?
