nordic moto garage
XS650 New Member
Hello,
I'm new to working on motorcycles and I got a xs2 last summer. I had to change the 3rd gear because it was broken. I took the whole engine apart to learn and fixed the gear. Put it back together and it ran smoothly for a short period. First I had fuel running straight through the carbs. I adjusted the floaters (25+mm) and haven't had any fuel leak problems after that. I started the engine and it started to backfire and run bad, and stopped. After that I haven't got it running again.
I think it's wrong timing and I think I got the timing ok for it to start at least. But it does start. I read in the Owners Workshop Manual that a condenser at fault could make it difficult to start or misfiring. I think I did the test but I'm not sure. Added a video of what I did:
"If the engine proves difficult to start, or misfiring occurs, it is possible a condenser is at fault. To check, separate the contact points by hand when the ignition is switched on. If a spark occurs across the points as they are separated by hand and they have a blackened and a burnt appearance, the condenser associated with that set of points can be regarded as unserviceable"
There is compression, spark and fuel/air
Anyone have any tips on how to get it running?
