The original '70 - '71 drum brakes used a 34mm fork up until mid '77. After that they switched to 35mm forks.
To swap to a disc brake, you'll either need '72 - mid '77 front forks (34mm) that have the caliper mounts and matching caliper, and any year disc wheel.
Or you'll need the triple trees, caliper, and wheel from any year after mid '77 (I'd go with '78 just to be on the safe side) since the 35mm forks won't fit your triple trees.
Don't forget the spacers and axle either.
How hard is it to find parts in Aruba?
