cleoncleon
Hello all, got a bunch of stuff here I want to let go of.
Need to make space/funds for the current Yama650 build.
- Price and Description will be right ABOVE each photo/set of photos.
- Shipping is not included but I do try and ship as cheap as possible.
- PayPal or Cash; I also accept reasonable offers, I will reduce price if multiple items are purchased to make it more of a package deal.
- Will Accept Trades too, looking for XS650 Parts: 2-1 Headers, 5th Gear Over., 32T Sprocket, Banshee Flywheel/Magneto, Pillion Seat, Small Tanks (Wassel Style etc..).
1. Early XS650 Pipes. Have a nice High Upsweep. No holes or Pits, ready to be installed. Has some surface rust on Mufflers, The headers look pretty good. Comes with Flanges and Brackets for mounting. - $70
2. - 75' (S650-XXXXXX) Complete Head w/ Jugs. Original to engine, All Factory Matching numbers. - $70
- 256 Camshaft, I also have a Matching Crank Set w/ Rotor still on. - $50 for Shaft. $90 for set.
3. - 75' Right Side Cover, Damaged. Has crack in the side. If you can weld, you should have no problem here. - $20
4. - Early Tank, Not too much rust inside, Rinse with some CLR and you should be good to go. Comes w/ Both Petcocks AND key. - SOLD
5. - Some Shocks. One on the LEFT are 650 Shocks, Ones on the RIGHT are off a 74' Honda XL250, 1" Higher than the XS's. - $30 for XS/ - $25 for Honda
6. - Carbs off of a 1980's Honda Rebel 450. Slides/Diaphrams feel good. - SOLD
7. - XS650 Charging Stuff - $40
- XS650 Guages, Speed/Tach - $25
- XS650 Control - $15
8. - Late XS650 Kickstart, Later one with Circlip and Spacer. - $40
- Tri-Point Tappet/ Valve Covers - 3pcs. $20
- Shift Lever, Little Bent - $12
- Oil Lines - $15/each.
9. - Rear Fender - $20
- Passenger Footrests - $10
- Rider Foot Rests - $15
- Headlight Ears, One Bent as fuggg - $10
10. - XS650 Headelight, Lamp and Bucket - $40
- CL360 or CL350? Headlight Lens - $20
11. CL360 Stuff On top - Steering Damper of a Sport Bike - $20
- CL360 Style FootRests - $15
- Front Axle - $8
- Kick Starter Lever - $15
XL250 On bottom.
- Gauges - $25
- Grab Bar and Signals - $20
- Headlight Mount - $12
- Front Axle - $8
XL250 On bottom.
- Gauges - $25
