Punkskalar
Hugh's HandBuilt
Well folks, selling the ol' gal - for real ....
While she isn't perfect, shes a great bike.
The Good:
Engine:
Will have a NEW 750CC (Gary Hoos JE Pistons and Liners) 277 Rephased Engine installed. Never Run To Date (Will only install upon sale of the bike)
5th Gear OD
XS1 Camshaft
Permanent Magnet Alternator Conversion - Hugh's HandBuilt
Bead Blasted Cases, Cylinders, Head, etc...
3 Angle Valve Grind
Deleted Starter
New Cam Chain
New Cam Guides
All New Stainless hardware
Heavily Ported Head
34MM Lectron High Velocity Carbs ($750 New)
Hugh's HandBuilt Long Runner Intakes
8 Pack Clutch
1 Piece Clutch Rod
HD Throwout Bearing
Polished Side Covers and Valve Covers
Pamco 277 Ignition
Custom Chrome Ignition Coils
All New Seals and Gaskets
Re Chromed Cam Covers
Custom 2-2 Exhaust
Brass Head Washers
Frame:
Black Powdercoated Frame
Stock Front Loop with Custom Tail - "0" stretch
Chassis:
Shaved, Lowered, Polished and Rebuilt Forks with NEW Upper Tubes
Shaved Upper Triple Tree
Inverted Risers
Custom "Speedway Bars"
Custom Chromed Foot Controls
Knurled 6061 Al Pegs and Grips
NEW Slimline Master Cylinder
NEW Front Brake Caliper/Pads
Drilled and Lightened Front Rotor
NEW Timken Steering Bearings
HandBuilt Seat Pan - Custom Covered
3" Barrel Springs
Foot Clutch and Hand Shift (can easily be converted to standard shift/clutch if needed)
520 Chain
NEW 17T Front Sprocket
NEW 32T Rear Sprocket
NEW Wheel Bearings
NEW Axles
21" 1968 Ossa Akront Front Rim laced to shaved, lightened and polished front hub with Buchanan Spokes
18" 1972 Husky Akront Rim laced to Polished Stock Hub with MikesXS Spokes
Avon Speedmaster/Safety Mileage Tires
4 Lbs Battery
Bates Style Headlight
HandBuilt Fuel Cap
RARE 1957 Famous James Fuel Tank - RedKoted
Dual Petcocks with Reserve
Modified Front Fender in Rear
NEW Chain Adjusters
Side Mount Plate and Taillight
The Bad: (this bike was built to ride, and be ridden hard )
Paint is chipped and peeling in a few places on tank and fender, I can get this fixed (negotiable)
The Frame has a few knicks in the powder, no rust or anything like that, but its not perfect.
Tires has about 75% Tread Left
NO TEST RIDES - If you want this bike, you can put cash in my hand and then ride it.
Bike will come with All Copies of Magazines and Articles it has been featured in, along with a clean title (1981 model)
If you need more details about the bike, here is my build thread.
http://www.pirate4x4.com/forum/showthread.php?t=719041&highlight=
And the Feature on XS650Chopper.com - http://www.xs650chopper.com/2009/06/rephased-xs650-chopper/
Asking $8500 OBO with NEW engine - No Trades for other bikes please - I got plenty of those
$5,700 OBO as a rolling chassis - (Minus engine, charging system and ignition)
The Good:
Engine:
5th Gear OD
XS1 Camshaft
3 Angle Valve Grind
Deleted Starter
New Cam Chain
New Cam Guides
Heavily Ported Head
8 Pack Clutch
1 Piece Clutch Rod
HD Throwout Bearing
Pamco 277 Ignition
Custom 2-2 Exhaust
Brass Head Washers
Frame:
Chassis:
Inverted Risers
3" Barrel Springs
520 Chain
NEW Wheel Bearings
NEW Axles
4 Lbs Battery
HandBuilt Fuel Cap
NEW Chain Adjusters
