Wanted - XS650 Standard/flat Seat
Nice seat, I'll consider.
I know nothing about the construction of these seats. I assume that the pan is the metal foundation. Does the cushion separate from the "Pan" and assuming so, how is it done?
Thanks for Seats 101 !!
You can very carefully cut it loose from the pan after you remove the cover, i can get you a better pic of foam under cover if your interested and if it'll work for you, i'm not the best identifying which years work with others as far as shape of pans and yes the pan is the metal under the cover and foam of your seat.
DJ Dave
