XS650 tracker build(first build)
tunedbytyler
Morgan hill, CA
Hey Guys!
purchased an old tired 1978 xs650 standard about a year and a half ago as my first bike. Used this bike to get my license, and rode it a good amount before getting tied up in other hobbies over the fall/early winter.
after sitting for a few months, and friends making fun of my "POS", one of my buddies recommended i turn it into an ART bike. I do custom bicycle paint for a living, so i jumped at the idea to paint something on a larger scale. Little did i know, this would turn into one of the largest projects i have attempted yet.
plans:
1. FRAME
-- remove airbox/battery box
-- make custom electronics tray under seat
-- detab entire frame(remove fender mounts, centerstand+mounts, airbox mounts, seat mounts+lock, passenger foot pegs, reflector mounts, handle, exhaust mounts
--brass swingarm bushings
--angular head tube bearings
2. ENGINE
--electronic ignition (boyer)
--PMA (xscharge)
--new gaskets/seals/hardware
--new pistons(.025 over)
--barrels machined to match(work done at Marinos auto machine shop in Watsonville,Ca)
--paint entire motor black(gold leave logos)
--starter delete..never worked, never really minded. taking out starter motor + internal gears
3. SHOCKS
--14.25 progressive shocks
--will need to make something to protect the swing arm(haven't decided if i want to buy something and refab it or just make something from scratch.)
4. FORK
--emulators
--shave extra brake mount off left fork leg
--paint lowers
--new seals/boots/rock shox fork oil(15wt, slightly overfilled)
--fork brace(tarozzi)
5. WHEELS
--new rims(slightly wider to run shinko 705's)
--new stainless spokes+nipples
--paint hubs
--new bearings+seals
6. COCKPIT
tracker bars(tc bros or builtwell)
--brembo 11mm master
--dogleg clutch
--magura 314 throttle assembly
--motone 3 button(blinkers/horn) not 100% yet
--motoscope mini, or motoscope pro...i think...
7. Exhaust
-- pandemonium ya mama exhaust
--shave welds off pipes
--paint black with heat resistant paint
--wrap just section under guard in black heat wrap
-- custom cl175 heat guard
8. TANK
--xs400 square tank
--make rear tank mount
--decide on petcock setup(very tight with rear tappet cover). may machine adapter plater for 3/8 npt petcock so its angled slightly outward.
9. SEAT
--fiberglass seatpan with upwards indent to help with electronics room
--figure out how to make a seat...
Here are a couple pics of first getting it home in my 72 datsun 521, and the early teardown stages
i started on the frame first. When i took apart the bike i labeled every tab so i would know which ones to cut when the bike was apart. as stated in the first post i removed fender mounts, centerstand+mounts, airbox mounts, seat mounts+lock, passenger foot pegs, reflector mounts, handle, exhaust mounts and other bits that were deemed unneccesary.
I used an angle grinder for everything, starting with a cutting wheel, then a grinding wheels, and lastly, an 80grit flap disc to smooth it all out. pretty happy with the results and the fact that i wont really need much if any bondo.
overall i lost about 4lbs in mounts alone, and this only counts what i could cut off and not what was grinded afterwards. in addition to the mounts, i dropped the weight of the fender(or half of it), the centerstand, the airboxes/battery, steering lock and passenger foot pegs. in addition to removing mounts, i shaved down a just about every weld(while doing so safely) and chopped about 2" off the rear end. i still need to purchase a welder(and get better at welding) to finish the frame, but am nearing completion.
***thinking of trying to fill the hole from the steering lock with a dime...we'll see. threw a couple mock up shots with the exhaust/tank for excitement!!
Hello, i am up in Sacramento.
Are you willing to sell the exhaust?
How does it look, dents, rust, etc...?
Thank you.
Next up was the fork. wanted to remove the extra brake tabs, rebuild them, and paint the lowers in the "art bike" theme. cut the extra brake tabs off with a cutting wheel and ground them smooth with a grinder/80grit flap disc. after getting the brake tabs smoothed out, i sand blasted the lowers and painted them along with the upper and lower tripples. these are the first part of the bike that i painted and it is rewarding to finally see something finished after the countless hours up untill now. keep in mind this is an "art bike" and not painted to be subtle. Enjoy!
Okay, that is some "wild" paint choices!
Your Art bike build is very interesting! Very nice work on the frame. Your 78 is going to be quite unique obviously.
Since you are going for good looks, I would recommend you find a breather off of a later 80's engine to replace the oversize 78 dual breather box..
A 78E is a sweet year to make a custom out of. Hope to see more pics too !
-R
It is actually a sweet year to keep original as well, or at least avoid irreversible mods. At least that's what I am trying to do with my 77D. The only thing irreversible so far, was cutting/grinding off the handle on the LH subframe, for lifting the bike onto the centerstand. Because it fouled my Denfeld luggage rack/ pannier holder.
Cutting up Specials is totally OK in my book, but remember I am a low handlebar kind of guy :)
Got the barrels back from Marinos machine shop. got them washed and scuffed up along with the rest of the engine. after getting everything scuffed i used an etch primer and spayed it satin black. just finished everything today. Going to let it dry for a day, then start reassembly of the motor. ignition and PMA are supposed to be here tomorrow so hoping to get everything back together over the weekend and clean up all the small parts cluttering the workbench currently.
in addition to paint, i was able to make the underside of the electronics tray. cardboard template, to aluminun then grinded/filed/sanded to fit just right. going to weld mounts to the inside that will hold the tray. i do not plan on running a battery(boyer box instead) so hoping i can fit everything in this space. i also plan to make a fiberglass seatpan that will have an indent molded into it to help make room as well.
NEXT... i am stripping and doing some light body work on the gas tank. no major dents, just slight imperfections. this will of course be the showpiece of the art bike so i plan on it taking at least a week if not 2 to paint.
Picked up a welder a couple days ago and got all the welding on the bike done. just used flux core so i didnt have to get gas, and knew i was going to be grinding the welds down anyway. i had taken a welding class at a jc a couple years ago, but this was my first time welding outside of that. figured it would be a good time to learn since nothing was heavily load bearing.
- rear tank mount
- electronics tray mounts
- brake lights/spring mounts(removed w/ passenger footpeg hoop.
- rear hoop
in addition to getting the welding done, i started getting the motor back together. got the valves back in, piston rings in and clocked, and barrels and head back together. need to install ignition and pma still, as well as getting everything set up.
Got the tank started! As someone mentioned, my xs650 tank and side covers were in extremely nice condition, too nice to justify painting. So i hunted and found an xs400 square tank that had a couple dings as i knew these would be easy to fix.
Order of operation went as follows: etch primer, bondo, fill primer, sealer, base color(which is the base for everything and the color the frame will be), artwork, clear. at this point i am a bit stuck. i had further plans for the tank, but i am in love with the current state. thinking some gold leaf logos and call it a day.
next step is a fiberglass seat pan which i need the tank on the bike for, so i'll have a couple days to think about it.
I’m curious , how do you achieve that multi hued swirly paint? I’ve never seen anything like that. :umm:
Just catching up your fast progress ! You seem to be both fast and skilled. Please do keep posting pics of the build. Very interesting :cool:
I think your paint theme has an outer space kind of look going. Kind of like looking through a telescope outside of our solar system. Very cool!
Quick update, been a busy couple of days.
- Got 2 seat pans made of fiberglass.
---One to attempt to make a seat myself and one to send to someone that knows what they are doing. I put a large indent in the pan to make room for electronics and im worried it might be too much, but wont know till i get foam on it.
- got the exhaust sprayed matte black with high temp paint.
---plan on wrapping the exhaust or at least the rear portion, but didn't want to leave it raw.
- Got the frame stripped down to bare metal, and primered with an etch primer.
---plan on hitting it with a fill primer, then the base coat/clear which is the same navy as the hubs.
- lastly i got the wheels laced up!
---in a recent past life i was a professional bicycle mechanic, so luckily the wheels werent bad at all, slightly easier than a bicycle wheel to be honest since spokes never go under eachother.
I'm sure watching this build !
And also very jealous of you having all the skills and equipment to use it with !
Like, who has a bead blast cabinet large enough for a car ?
Lol, -R
:thumbsup:
