XS750 - loud valve clicking ( chain? )
misiek303
Chicago
Hi
The clicking comes from the fast-releasing valve lifters and this is due to the loose chain at some point. The chain is tensioned but while turning the camshafts there is a short time when the chain is loosened between the Exhaust and Intake camshafts. I am not sure if that kind of loose chain at that moment is ok or if this chain has to go.
All valve clearance in spec. The timing alignment is perfect.
I attached the images and a link to the short video to record the sound of the clicks, at the end of that video you can see how the chain getting loose.
https://photos.app.goo.gl/Cf7vpGAyoPksVKi98
Any ideas?
Thank you
There is probably some alignment marks for the cam chain on the sprockets .I would check so these are correct .
So the chain has not jumped on the sprocket getting out of sync With a loose chain
? Bent valve stem ?
? Bent valve stem ?
Yes, both sprockets align with the marks on the camshafts. And that also aligns with a T mark on the governor for TDI.
Found the problem. It was not a valve click. It was a snap of the timing chain guide against the headblock.
I guess I tensioned the chain at the wrong moment. It was really bizarre, but now everything was so silent and the loose is gone.
I am excited again.
Sometimes I just need to talk it through.
Thank you.
