Sorry guys I have searched all over and can't find a problem similar to mine. I have a 75 XS650B......all stock except Pamco High Output Ignition, pod filters and main jets that are one size larger than stock. All the rest is stock. My carbs are synced perfectly, floats are both 24mm from flange, and both carbs have all new parts....jets, gaskets,needles,etc. Both carbs seem to be 100% equal on both sides and totally cleaned. Seem to be!
Anyway, the bike fires up great, with responsive throttle. However, the right side idles somewhat sporadic and back fires under acceleration. The left side runs very very smooth and does not back fire. Funny thing is is the right side with the back fires runs about 30 degrees cooler than the left. The left side seems to be getting way hot....270 degrees or so. The left side is turning my pipe blue. With my carbs set completely equal I can't seem to figure out why such a huge difference in the way the two carbs operate.
I have noticed the left side carb with the choke lever has an extra jet inside the bowl on the front left of the carb hanging down. The right carb has a hole there but no jet hanging down. Not sure what the affect is of this jet or if it is from the choke being on that side or what.
Any ideas guys???
Any ideas guys???
