ippytattoo
Just another grumpy old hack.
First off let me say thanks to osteoderm & Travis for putting me on this path and helping out with finding a suitable slave cylinder and master cylinder combo.
Here is my experience with a hydraulic clutch conversion:
The parts I am using are as follows,
slave cylinder from a 2009 Aprilia RSVR 1000
MikesXS clutch master cylinder part#08-0261
Modified left hand side cover as described in osteoderms: Good Heart, Bad Intentions: another build thread
Made a new clutch push rod to replace the original short rod from 5/16 round rod cut to 140mm. When I pull the motor I will be making a single solid rod to replace the 2 rods and 1 of the steel balls.
I was first going to use the Magura master cylinder from MikesXS part# 08-0252 but they were not available so I decided to use part# 08-0261 since the bores are nearly identical. When I received the master cylinder and matching brake master cylinder I noticed that the lever was not making contact with the piston when everything was in the resting position (approx. 4mm gap between the 2). Also I wasn't getting the full travel of the piston (lacking about 4mm of travel). So I took the pistons down to a local machine shop and had them drill and tap them for an adjuster screw/spacer
Plumbed up everything with some front brake hoses for testing.
Now for the fun part, measurements(sorry no pics of the meauremens):
With my stock lever and cable at the end of the adjuster screw I was measuring 4mm +/-, 3mm +/- at the pressure plate. So i was having about 1mm of wasted movement in the clutch screw and rods.
With the hydraulic clutch I am getting 3.5mm +/- at the pressure plate. I haven't figured out how to measure at the piston just yet.
The info from Travis's spreadsheet for a 12.9mm master cylinder with a 16mm stroke and a 28mm slave cylinder shows I should be getting around 3.4mm of travel at the piston, so it appears that there is less wasted movement in the hydraulic clutch assembly.
Let me know what you guys think I will add more pics later.
