I made a 25mm clutch slave cylinder a while back and bought a 9.5 mm master cylinder to use with it. I hooked everything up, but in testing it found I only had 1mm movement on the slave cylinder piston, so, obvioisly the 25 mm piston slave cylinder was to big.
I had a couple of 20mm hydraulic seals lying around, so next I made a 20mm slave. A thing of beauty: 6061 ally body, stainless piston, hydraulic ram seal, and instead of using a circlip to keep,the seal in place I made cover to keep the seal from popping that also doubles as a dust seal. Ae beautiful piece of work, even if I do say so myself. But, when I went to hook it up I found the master cylinder had jammed. Managed to get it apart but found the seals had expanded and when I pulled the piston assembly out, one of the seals was damaged. Obviously the master was meant to use brake fluid, not mineral oil as I had used.
So I looked for a repair kit, only original KTM kits were available for big bucks with no garantee it will fit. So, all in all, a monumental f-up.
So, it's back to a cable clutch and the slave I made is destined for the bin, along with the master.
In fitt'ing the hydraulic slave I had to modify the clutch cover, so now I have to see ifI can repair the clutch cover to fit the original plastic screw actuator.
Modifying bikes ain't eaay!
