I agree with most everyone. I might start with getting a repair manual. The factory book is best, then the Haynes, then the Clymer. Biker.net has them as a free download. Start by checking the sump filter for tears, replace or fix, I fix, clean well patch over the hole with a piece of soup can and JB weld.
While the sump plate is off feel around with a finger up in the engine, looking for bits of black plastic. If you find any, the front cam chain guide is going bad, Metal bits in the filter or the sidecover filter generally means the chain guide is already gone.
After this good fresh oil most any brand 20w50 oil will work, motorcycle specific is better.
Now you should check the cam chain tension. set the valves, check the points gap and timing. New plugs, fresh gas.
At this point you can either clean the carbs or try starting. You will probably need some carb attention, most do.
When it starts recheck the cam chain tension with the engine idling. The rod should come out to flush with the adjuster and move in and out about 1-2 mm's.
Now is a good time to check battery voltage. Before starting battery should be atleast 12.5 volts. with engine idling lights off about 12 to 12.5 volts. As you rev the engine the voltage should pick up to 14.5 at much above idle and should not go over about 14.5volts. if no rise alternator checks are in order, if to high regulator checks.
Now to the clutch. Loosen the adjuster at the lever to give plenty of freeplay. Now down on the left side cover you will find a round chrome cover. About 1 1/2 inches in diameter. Remover this cover, screwdriver slot on the bottom.
Under this cover you will find an adjustment screw with a lock nut. Lossen the nut, while holding the nut turn the screw in and out a few times to get the feel of it. Turn the screw in til you just feel resistance, then back of 1/8 to 1/4 turn, lock the nut with out losing the asdjustment. Now at the lever adjust to 1/8 to 1/4 inch freeplay.
At this point if the tires are ok. Not weather checked or no thread. you can try riding it slowly to check brake and clutch action.
I might replace and flush the front disc brakes with fresh fluid before a test ride. If it seems ok a bit faaster to check gears and handling.
As you ride it it will tell you what it needs.
Things like head bearing , swing arm bushing, wheel bearings and wheel true and balance. Drive chain and sprockets. Rear shocks front fork oil and springs.
This should get you going. Just remeber the bike is a few years old and needs some TLC, we all have had moments when we think "What have I gotten into" Don't let these thoughts deter you. You will over come the rough spots to find a bike that is a joy to own and ride. As we all have. And Welcome to the board. XSLeo
