alfredo
1978 xs650 Special
Just finished up my rephase project, got everything tightened up and took it for about 10 miles. Was riding at night with the headlight on and it cut out around the 7 mile mark at a stoplight. I turned all the lights off and was able to kick it to run, but it would only run at about half speed and cut out if I ever let off the throttle. Was able to putt home with no lights and holding the throttle open.
At first I thought I blew the crank seal, oil sprayed on the PMA and it couldn't charge. Well, I have since investigated and it was bone dry. I checked all the fuses and everything is good. The battery is a new Shorai and should be fine.
I am thinking I was running the whole time on the battery and the PMA was never recharging it. I don't know how to troubleshoot or test really. I just drew how my setup is wired. The 20amp is perfectly fine. The only thing I will say about the install is that when I got the kit, I got a female connector from Hugh instead of a male. So instead of wiring up the connection like in his instructions I just soldered on Male connectors and inserted them into the female.
Anyone have tips on how to see if my setup is charing and its just the wiring? Could it be something else? Any help would be great.
