Well I've finally got it all buttoned up and got it to fire a few times. Looks like my PMA regulator isn't working. I'm getting about 18vdc. But Hugh said he'd send me another one. When i degreed the cam i was getting about 3 degrees advanced. I got the cam from Mr.Riggs, and i did the crank. Well from what I can tell that would advance my pamco with it. I noticed immediately a consistent kick back as I was trying to kick it. Once I finally got it started and the timing light on it, it was at or past advance at or around idle.... I've already adjusted the pamco plate as far as it will go (counter clockwise as you face the pamco), and tried taking the slop out of the pin at the mechanical advance that drives the pamco rotor... Is it possible that cam is so far advanced that I will not be able to get the timing right? The cam only rotates half of the crank, so seems like it would have to be way out to have to adjust it that much?
Is it possible i could have something installed wrong and yet close enough to still run? Seems like the pamco install is either right or wrong, and wrong as in it will NOT start. But I could be wrong.... I'm all ears....
