shotgunjoe
XS650 Hunter
Sounds like a good reason to eliminate the auto advance altogether.
Are you referring to the slash marks on the little advance disc and the advance unit main plate? The ones on my original unit don't align exactly, never have (yellow arrows), but I just attributed it to wear in the unit. It's always timed up fine though .....
Thanks for the feedback. The cam and crank were done by Hugh and am not questioning his work in any way. I have double checked my timing marks, itnitally it was done visually looking thorugh the spak plug hole, but then to be sure I made a piston stop and set it up thanks to Hugh's isntructions. I also assembled the Pamco per Hugh's instruction. All three pins are in place on the advance shaft and on the cam. Just for some background new parts in the motor are rods, pistons, cam chain and guides, valves, valve lash screws, cam and crank rephased by Hugh, pamco ignition and PMA charging system.
I beleive I have two issues, the cam timing seems to be off. What I'm not 100% comfortable with is what the actual specification for the 447 cam timing.
If I use the lobe center method with zero lash and read opening and closing of the intake values at 0.050" lift I get a lobe center of 104. I've seen posted, I think by mriggs that the lobe center specification is 106. I think that comes from using the opening and closing values published in the manual to calculate lobe center? However those values seem to be based on a lash value of 0.002" and from the lobe center theory it sounds like that can lead to inaccuracy due to variation in the cam base circle. But since these are published numbers by Yamaha and not measurements it may be irrelevant.
The manual also says to check cam timing set the lash to 0.012" and the intake valve should start to open at 47 degrees BTDC, with this method mine is opening at 32 degrees.
The second issue is that when I put the timing light on the left and right cylinder with respect to their TDC marks the right cylinder seems to be advanced 10 degrees more the the left.
I think the plan will be to try and rotate the cam gear and get the cam timing right, then tackle the ignition timing.
Can anyone confirm the correct or best method to check the cam timing?
