XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 08-16-2013, 03:46 PM   #1
timeconsuming
In Nonsense Is Strength
timeconsuming's Avatar
Default Ebay Rebel 250 shocks
Hey guys
I'm sure this topic is overdone but search function led me to old for sale threads...
Anyway I'm considering picking these guys up and was curious if anyone had experience with 'em and anything worth noting about running them before I drop in to a hasty ebay purchase.
http://www.ebay.com/itm/Honda-Rebel-...71257896585%26
I plan on lowering my forks in the triples about an inch or so but dont mind a slightly taller front end, and I have my fender chopped so I don't forsee issues with tire rub.
timeconsuming is offline   Reply With Quote
Old 08-16-2013, 05:29 PM   #2
Gene
House of Detention
Gene's Avatar
Default Re: Ebay Rebel 250 shocks
You may have to shorten your kickstand once you lower your forks and put these shocks on. The center stand is going to be really hard to use as well.
Gene is offline   Reply With Quote
Old 08-16-2013, 07:06 PM   #3
jd750ace
Front Toward Enemy
jd750ace's Avatar
A rebel 250 is 150 pounds lighter than an XS, and has about 20% less unsprung weight to manage. They will be under sprung and under damped as well. If you don't mind a hobby horse bottoming out pogo suspension, go ahead and buy them. Good suspension costs good money, and is made for, or tailorable to the application.
Just 2 pennies worth.
"I've never had a problem with it" does not make it a good idea.
1979 Special II. K&Ns in air box, Pamco with E-advance, Dyna coil mostly stock.
2003 Road Star Silverado Silver Edition
2002 SV650
jd750ace is offline   Reply With Quote
Old 08-16-2013, 07:50 PM   #4
angus67
xxxxxxxxxxxxxxxxxxxxxxxxx
angus67's Avatar
I also have a 2003 marauder Suzuki. a lot of guys put the rebel shocks on them. its a 500lbs bike.
I got a set of savage shock for free and tried them, no pogo. savages are lighter too. the savage and rebel shock mount exactly the same, the savage shocks don't have those holes around the bottom, wich I don't like. I just have the preload on the stiffest setting. on the marauders, it lowers all most 2 inches. The stock marauder shocks have a cover over the spring, and I wanted to see the spring. savage shocks aren't as shiny as rebel shocks, but like I said, got for free.
So, that's another shock that fits the xs. later savage shocks.
1971 xs1b 3600 miles
1980 xs chop, bored to 680, kick only. ridgid. bs34's xsjohn's needles. 46pilot, 140 MJ.
1980 xs bobber. electrical nightmare. Destined to be xs1-b clone
2003 suzi marauder. Debaffled, stage 3 carbs.
angus67 is offline   Reply With Quote
Old 08-16-2013, 08:57 PM   #5
Gene
House of Detention
Gene's Avatar
I've been running the rebel shocks and haven't noticed the pogo stick effect or any type of bottoming out. I only weigh in at a light 200lbs...
Old 08-16-2013, 10:08 PM   #6
Dieselchanic
Intermittent builder
Dieselchanic's Avatar
Default
I haven't ridden mine yet but the rebel shocks seem, if anything, stiffer than stockers. I also have my forks 1 inch down in the triples and it sits strait up and down on the stock kickstand and is a pita to get on the center... I believe it's a direct swap as far as mounting. I'm running different top mounts so not positive.
'81 xs650 hardtail•PMA•Pamco•E-Advance•Sparx
There's a fine line between genius and fruitcake... I try to walk that line.
Dieselchanic is offline   Reply With Quote
Old 08-17-2013, 05:42 AM   #7
jamesgs4
fuck this, let's ride!
jamesgs4's Avatar
the lower mount on the honda is closer to the swingarm pivot than on the xs, so the leverage changes. that is why those shocks work well on xs650's. some might say the ride is even a little stiff, compared to the stock xs shocks.
jamesgs4 is offline   Reply With Quote
Old 08-17-2013, 05:53 AM   #8
jd750ace
Front Toward Enemy
jd750ace's Avatar
Quote:
That makes sense. After studying some pics they are laid down considerably as well on the Rebel.
2002 SV650
Old 08-19-2013, 11:05 AM   #9
timeconsuming
Thanks for the responses gentlemen!
I'm a light weight 150lbs and will be running solo at all times with the chance of maybe some camping gear on the back.
I'm probably going to go ahead and order these, so thanks again for the feedback.
Old 08-20-2013, 06:48 AM   #10
DogBunny
XS650 ThermometerDipstick
DogBunny's Avatar
I have been using a pair of used eBay Suzuki Savage shocks for a few years, and they are fine. But I too have always been curious about the inexpensive after market new eBay Rebel shocks that the original poster linked too. Are they just cheap junk, or are they any good? Would like to hear from any one who actually has those specific shocks, or from timeconsuming if he does but a pair.
1976 with points; 1979 with Pamco; 1982 with TCI; 1977 XT500; 1990 Sportster
http://www.handspiral.com/ThermoDipStick.htm
DogBunny is offline   Reply With Quote
Old 08-20-2013, 01:04 PM   #11
timeconsuming
Well I'll be sure to report back. Here's to hoping they're not a waste.
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Wanted - On the lookout for some Honda Rebel 250 Shocks timeconsuming Classifieds 5 08-06-2013 01:54 PM
Brat Kit - Rebel Shocks off ebay? ryamatt The Garage 5 03-05-2013 11:05 AM
Wanted - Rebel 250 Shocks jasonslackisrad Classifieds 2 09-13-2012 10:16 AM
Wanted - Looking for Honda rebel 250 shocks! Juicyk Classifieds 9 03-29-2012 12:19 AM
For Sale - Rebel Shocks sentricity Classifieds 4 12-29-2011 12:38 PM
Tags
suspension
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
