Hoo-boy.... I'm gonna throw a wrench in here and ruffle some feathers. Be advised that many of the fasteners and threaded holes use a non-consumer 'Class of Fit'. Look at the attached pic (thanx RD51), and the aluminum chips collecting below. The tap, while of the correct nominal size, is larger than the closer 'class of fit' of the factory tapped holes. The resulting hole may not hold to the original torque specs.
Class of Fit explaination:
http://www.katonet.com/article/science.html
This can get into a very exhaustive research project, trying to find the original specs for all the fasteners, including cut and roll-formed threads. To learn more, try googling 'metric thread class of fit'.
Best I can say for the moment is: If at all possible, try to cleanout the threads without cutting the aluminum.
